06-22-2024 02:22 AM (Last edited 06-22-2024 02:22 AM ) in
Galaxy S- Mark as New
06-22-2024 04:07 AM in
06-22-2024 06:02 AM in
06-22-2024 06:03 AM in
06-22-2024 11:01 AM in
06-22-2024 11:19 AM in
06-22-2024 11:25 AM in
06-22-2024 11:28 AM in
Galaxy S1. except essential apps, put all your apps into deep sleep mode, occasional notification apps in sleep mode
2. turn off unnecessary options like wifi scanning, bluetooth scanning in location settings. nearby device scanning in connections setting
3. Turn off location, Bluetooth and nfc when not in use.
4. Use light performance mode if you want.
5. Restart device once in every week.
6. Screen timeout 30 secs
7. Turn on data saver under connections
8. Using 5g is upto you, but understand that will drain more battery. I'll suggest using LTE and use 5g whenever required.
9. You can also turn off auto sync if it doesn't required.
Use this and wait for 3 days and inform if you find any changes.
06-22-2024 11:51 AM in
06-22-2024 12:01 PM in
