S24 5g issue after factory reset.
(Topic created on: 04-28-2025 10:42 AM)
vivek1989
It has been stuck in febuary security patch since i have factory rest after updating my s24 5g to oneui 7.0.
Before oneui 7.0 and before factory rest it was in march now after rest it went one month back to febuary update not even getting google.updare.
And also not able to find main components for google for 2025 march
vivek1989
Enable the app.
anil363
Nhi ho rha
vivek1989
Disable karke rakhe ho kaisa dikhayi dega bro
vivek1989
Check whether u have disable the app or moved it to archieves check .app disable hai
anil363
Kha se check hoga
vivek1989
Pahla screenshot go to
1 setting
2.apps
3.scroll down to that concerned which have been disabled.
4.click on the aopp
5.enable it.
2nd screenshot kbhi kbhi kya hota hai device khud aisa apps ko deep sleep mein daal deta hai,jo zyda battery consume karta ho ya mahino ya dino se use nhn kiya ho.
1.Now 1 open setting
2.scroll down to battery
3.click on battery usage limit
4.
There u can see sleep and deep sleep check whether ur concerned apps r in deep sleep or sleep mode.1745819862971.jpg1745819862993.jpg
anil363
Bhai jab se one ui7 beta update hua h tab se h ye problem and instagram youtube and amazon
vivek1989
Hmm!.
Yeh sirf whatsapp ka hi hai ki youtube aur insta ka bhi enable karna padega
anil363
Nhi ho rha
vivek1989
The screenshot u have show click in on uninstal and try to reinstal it.it might solve.
