5 Comments
Rohil__1787
Wednesday in
S24 ultra also worst
BiRdMaN
Wednesday in
ScAMSUNG gave us BUG UI 7
BiRdMaN
Wednesday in
This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others. Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
jeets1909
Wednesday in
Instead i should stop using my phone. Right? Man stop being stupid and giving stupid suggestions. If i had to use my phone such less than why would have bought this premium phone.
BiRdMaN
Wednesday in
It is a BUG send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you 😊
