S23 ultra OneUI 6.1 lag and stuttering in OneUI home
(Topic created on: 03-28-2024 11:35 PM)
MyInnerDemons
As you all can see after the update to OneUI 6.1 there is lag and stuttering in main page of UI. When we swipe up from home there should be blur or some what black background(when blur removal is on) but here we see the main screen wallpaper very clearly which should not happen.
Kindly report this to samsung.
Thank You
12 Comments
ankitmon
And where's my good old samsung navigation gesture settings?? This is so stupid. I hate the android navigation gesture so much.
MyInnerDemons
It had to done bro because of the feature requirement.
ankitmon
No, the circle to search is just basic assistant toggle. Which already worked with all the gestures. Be it samsung's or android. There was no need to remove this feature.
MyInnerDemons
Yes that's right we can have gesture to trigger the circle to search but for now we don't have that option. But later samsung might give us that option to customize.
ankitmon
They already gave it in s24 ultra. In navstar goodlock app. There should have been an option called extra navigation settings. Which brings back old navigation settings in settings app.
MyInnerDemons
Bro give samsung some time they will fix this. There are far more important problems than this now after the update to OneUI 6.1
Please report this and other issues as well.
ankitmon
What problems? It's working great for me. I don't have any other issue.
ankitmon
Except the keyboard issue after enabling the AI feature. It's laggy sometimes.
