S23 smart view case not working
(Topic created on: 11-16-2023 07:31 PM)
Athiran
Hi
 S23 smart view case not working under one ui 6.0 stable, when close or open,
Any setting?
17 Comments
Athiran
Yes brother.
Members_DB1n1Fz
Same here my s view isn't working as well  is there any solution
Athiran
Still window cut not working
Ms89
Is the problem solved because it appeared for me as well?
Athiran
No, still I have the problem 🥹
Ms89
This is really a big problem, unfortunately Samsung does not support, I will send a complaint
Athiran
I try everything brother doesn't work, also samsung service center visited they all said DEVICE reset option only
Anthonyisme2
Beginner Level 4
  • I have the same issue. Customer support said it appears the update disabled the smart case.
