S23 edge lighting style not working
(Topic created on: 12-23-2024 11:06 AM)
Kamilt
S23 edge lighting style not working 😕
3 Comments
Wodehouse
Edge lighting is a cool feature on the S23. Let's troubleshoot why the Edge lighting style might not be working:
Possible Causes
1. *Edge lighting disabled*: Ensure that Edge lighting is enabled in Settings > Display > Edge screen > Edge lighting.
2. *Notification settings*: Check if notifications are allowed for the apps you want to trigger Edge lighting. Go to Settings > Apps > [App name] > Notifications.
3. *Edge lighting style not selected*: Verify that you've chosen a lighting style in Settings > Display > Edge screen > Edge lighting > Lighting style.
4. *Software issues*: Sometimes, a software glitch can cause Edge lighting to malfunction. Try restarting your device or checking for software updates.
Troubleshooting Steps
1. *Restart your device*: A simple reboot can often resolve software-related issues.
2. *Check for software updates*: Ensure your device is running the latest software.
3. *Reset Edge lighting settings*: Go to Settings > Display > Edge screen > Edge lighting > Reset.
4. *Clear cache and data*: Clear the cache and data of the Edge screen app (Settings > Apps > Edge screen > Storage > Clear cache and Clear data).
If none of these steps resolve the issue, consider contacting Samsung support for further assistance.
If this answered your query please tap 3 vertical dots to the right of my reply and tap resolved. Thank you 😊
SumexP
cs_member8
Dear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Enable and set it in the Notification settings.
Path: Settings > Notifications > Notification pop-up style > Edge lighting style > Select Effect, Color, Advanced > ta ‘Done.’
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
