S23 battery quality has decreased
(Topic created on: 08-30-2023 09:25 AM)
sanjitgupta96
In the recent update
1. Only if I use phone for call from morning till the second half battery goes to 20
2. If I play CODM in medium setting then battery drains 15 to 20% in 20 mins playtime. Little heating takes place in the back
3. Have bought Mcafee for a year. When I start the Mcafee application it shows no wifi connectivity and only uses mobile network
12 Comments
Akshay_NS
Yeah due to android 13 August update or 5g
Hope samsung will fix this issue soon 😊
TimonN
Expert Level 4
No such issues with my S23
Devv_007
Good guardians >Thermal guardian and lower cpu threshold.
1. Check the network strength. If its low, it drains a lot of battery!
2. Playing games always drains battery. Game needs to be optimised by its developer.
3. Check permissions given to McAfee. If thats alright then you need to contact McAfee support once for diagnosis.
TimonN
Expert Level 4
I wonder why mcafee or any antivirus is needed. On mobile or even PC.
sanjitgupta96
Samsung and mcafee
1st year pricing was very little
For which I took the subscription
TimonN
Expert Level 4
Bro but is it needed ?
In fact such antivirus solutions make phones slow.
sanjitgupta96
Bro after downloading and purchasing the product understood this
TimonN
Expert Level 4
Ok, no problem. Now remove IF you are facing speed issues.
