S23 Ultra Problems
(Topic created on: 03-31-2024 12:57 PM)
ameal
I am not happy with my S23 Ultra phone.
These are the following reasons
Not able to enjoy full HD content on Hotstar
Sim Network problem
Battery Drain problem
Display Quality is not good
22 Comments
Luck-è
Kindly visit service center.. i am using s23 ultra not facing anything like that !
ameal
Did you compare with any other phone?
Did you buy S23 Ultra online or offline?
I was able to play full HD content on my previous phone Realme 9 pro plus
But with S23 ultra video quality is not good on Hotstar premium.
Luck-è
Why ill compare ! I don't have any issues with my device at all its working fine .yes i bought it offline
ameal
There is need to compare .
Internet Speed also play a role.
When I watch the same content on my TV quality is very good.
I can see small details like pimple on face.
When I watch the same content on my laptop quality decreases a bit . (Can't achieve quality of TV)
When I watch the same content on S23 Ultra it is so bad that quality looks like 480p
Luck-è
Set to the max resolution of the screen an then watch and use wifi for better network strength for watching hdr contents
ameal
It never worked
Luck-è
Then you should visit care to get solved your problem. How you using then your phone if you facing this type issue just called samsung care ask about it
ameal
If there is hardware problem then video quality should be bad everywhere ..
Video quality is good on Sony Liv and YouTube .
Bur not good on Hotstar and Jio Cinema and some other apps
ameal
Samsung Support is saying "Hostar and Jio Cinema are 3rd party apps". So They can't help
