S23 Ultra - GPS not working/ low accuracy
(Topic created on: 06-06-2023 06:30 PM)
DeepKing47
My S23 Ultra has an issue with its GPS,
Anyone facing problem with the GPS ?
Any solutions ?
17 Comments
salmanul
Expert Level 3
Open the Samsung Members app.
Tap on the "Support" tab.
Tap on "Diagnostics".
Tap on the "GPS" test.
Follow the on-screen instructions to complete the test.
The test will check the accuracy of your GPS and report any problems that it finds. If the test finds any problems, pls let us know
DeepKing47
I have done this already, it says GPS Accuracy Normal.
I have done all the things mentioned on the internet
Clearing google map app caches, re-installing the app etc.
kJrenZ
Beginner Level 4
Actually  they r bringing  camera and Ai but not focusing on the basic things  . its not a dual band gps  phone  vivo xiaomi  Huawei already have this years back.
DeepKing47
Please see the attached pictureScreenshot_20230606_175524_Samsung Members.jpg
DeepKing47
DeepKing47
App permission is turned onScreenshot_20230606_175943_Permission controller.jpg
salmanul
Expert Level 3
What about Google map..? Is showing exact location
And also use WhatsApp and share location to somebody, before sending look at the accuracy
DeepKing47
Google map showing, searching for GPS and low accuracy
DeepKing47
The current location is showing accurate, but while navigation it doesn't work
