S23 FE - Poor battery life
(Topic created on: 10-16-2023 11:16 PM)
ArpitS24Ultra
I am getting hardly 4 hours of screen on time for my new S23 FE. Anyone having same issue or any feedbacks regarding battery life of S23FE. Typically 4500mAh should give a full day backup for avg (non-gaming use). But I have to charge at least 2times daily to keep this thing running.
Edit: The on screen time os about 2.5 hrs despite after enabling power saving ticks.
105 Comments
itarunkumarP
I guess it can be possible with your unit. Because few of them just experienced like you!
Devv_007
Are you facing heating issues with this phone?
ArpitS24Ultra
Yes heating while normal usage also and especially while charging
Devv_007
Try Thermal Guardian app and lower its thermal threshold -
Screenshot_20231016_232754_Thermal Guardian.jpgScreenshot_20231016_232745_Thermal Guardian.jpg
harshshah1312
I am too facing the heating issue.
ArpitS24Ultra
Also, any idea what is the meaning of this symbolScreenshot_20231016_232427_One UI Home.jpg
Devv_007
Thats Light mode in Performance profile settings,it underclocks the cpu little bit.
CODM6567
Light performance mode
Ashwinash
It's looks like performance mode bro . .
