S23 FE Network Problem
(Topic created on: 10-25-2024 08:14 PM)
darshan33
I'm having some issues with the network on my S23 Fe. Sometimes, it switches from 4G to 5G
2 Comments
kundankrmahto
Even flagship phones don't have 5g only feature 😂😂😂
cs_member8
Dear Samsung member,
As per your query, kindly follow the easy troubleshooting steps which might help to solve the issue.
Note: kindly contact your network service provider once to make sure there is no issue from their end.
Check device network in open area
Check device network mode settings
Please follow the steps: Navigate to apps screen and tap on Settings>> Tap on Connections>> Tap on Mobile networks>> Tap on network mode SIM1 or SIM2>> Select network mode
Note: We recommend to set device network mode as 5G/LTE/3G/2G (auto connect) mode.
Check network operator settings
Kindly set device network operator as "Automatically".
Please follow the steps: Navigate to apps screen and tap on Settings>> Tap on Connections>> Tap on Mobile networks>> Tap on Network operators>> Select automatically>>
Note: We recommend to set device network operators as automatically.
Tap on OK>>Registered on network.
Check SIM cards
Kindly do check same SIM card in another phone or another SIM card in same phone to verify the issue.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
