S22 ultra battery draining too fast after latest updates
(Topic created on: 11-06-2024 11:14 AM)
psk_22ultra
Anyone experiencing battery draining faster after latest updates on s22 ultra?
3 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open the Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select Error report > select the appropriate issue category> Type your query and send).
