S22 Ultra weird display issue.
(Topic created on: 11-20-2022 12:28 PM)
Blazko
Hello all,
Need some help with a weird issue I'm facing with my 3 month old S22 Ultra.
Since almost a month, I'm noticing a bright flickering greenish tint light near the centre of the display screen that vanishes once you touch the display. It comes back again when the display is idle. I have also noticed this issue persists only when the adaptive motion smoothness setting is selected. In the standard setting, this weird issue isn't visible. I have attached a clip of this issue.
Chatted with the Samsung customer care but was fed with textbook responses. Also my phone is on the latest firmware.
Anybody else facing this issue or any idea what could be the reason behind it..?
7 Comments
Sid_Karna
Samsung's online customer support is a waste of time. You will be bombarded with copy-pasted robotic replies.
Did this issue start with any software updates? Samsung is known to introduce display issues with software updates.
Blazko
True about the customer care support.
The issue crept up, I guess so post the firmware update.
Sid_Karna
I would suggest you go to a service center before the warranty is over. Because mostly for display-related issues(even though caused by software updates) their solution is to replace the display altogether.
PraffulSingh
Take your device to service centre asap and submit it for diagnosis
Roshan5
Admit Your Phone to Authorized Service Center. Under Warranty Period
I have admitted my S22 Ultra Yesterday.
I am Facing Video Recording Problem only at FHD60 with AUTO FPS Option ON.
No Physical or Water Damaged.
Pinakin
Get it checked at Samsung Authorized Service Center and get it resolved. It would get sorted out don't worry.
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
