S22 Ultra Pretty Good Battery After Jan
(Topic created on: 02-02-2023 04:36 PM)
Kaizaadbanaji2608
Pretty Good Battery Back Up Post Jan Update
9 Comments
zeeXz
Do you use power saving mode?
No
zeeXz
Nice then
S_Kumar73
I'm getting max around 6 hrs SOT only. And that too I Uninstaller FB and few power hungry apps. But still getting around 6hrs only. Also reset my device after Jan update.
I didnt do anythin of these
S_Kumar73
May be ur S22 ultra manufactured in Apple factory 😃😃
_Sara_
Expert Level 4
Here's mine Screenshot_20230202_182919_Device care_1000013834_1675342759.jpg
This is what I am getting. 6 hours SOT. After the january patch.
Below 5% it drains 1 % every 30 second to 1 min.
On: bluetooth, gps, wifi,5gdata, nearby share(contacts), quickshare(contacts), connect to PC, calls and text on other devices, AOD (Always show) adaptive brightness and sync. Good lock all modules in use. Plus good guardian too with once a week app optimisation done.
Off: NFC, darkmode, dex, notification for every app unless something I need like whatsapp yes swiggy only delivery info and so on for every app. I restricted insta from using data in background and that improved battery a lot. Now i have restricted Instagram(only no other app) totally from background use plus notifications totally off for the app.
Phone almost always connected to watch and laptop via bluetooth and the connect to PC app.
Power saving mode is on only when I go to sleep which is 4:30am to 8:45am(about 5 hours)
Resolution: WQHD
Refresh rate: adaptive(120hz)
Single physical sim even though I have sims in both slots.
Network: Airtel 5g(max possible network in my area with always 5g in every corner on the house)Screenshot_20230203_163256_Device care.jpg
RELA619
Never got above 4-5hrs. If it is any OTT app I'll get 7hrs that's just because they use less batteryScreenshot_20230207_141124_Device care.jpg
