S21Fe Battery backup Issue ⚠️
(Topic created on: 10-22-2024 01:20 PM)
Anmolll
I have been using s21fe from last 2 years but recently after July 2024 Update my battery backup decreased drastically, and now I have to charge my phone for 2-3 times a day. Even I am not a heavy user still this battery doesn't last long, Please samsung look into this problem & provide a stable update for this battery issue. From last 2-3months I have stopped using 120hz refresh rate still not getting enough backup, also idle battery drain is almost 50-60% when mobile data, wifi, bluetooth is turned off during night.
And 1 more point that I have done a factory reset my s21fe 10 days ago.
still problem was not solved
Please Samsung solve this issue as soon as possible🙏
17 Comments
Not applicable
Same issue..
Not applicable
Same issue..ive started keeping a powerbank with me...battery drains in 2 hours
Anmolll
Let's Make this post viral so that samsung notices this problem and push a stable update for battery drain issue🥲
Anmolll
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
KclayD
Also share app 🔋 usage
Anmolll
KclayD
