S21FE Heating and battery draining problem
(Topic created on: 10-09-2022 11:42 PM)
himakush
Beginner Level 4
Samsung S21Fe comes under mid range category. But there is biggest problem of overheaing and battery draining. I hope samsung will fix these problems in next update. On battery point of view It required 2 to 3 times of charging a day on normal usage even it comes with only 25 watt charging whereas many competitior offers fast charging upto 120 watts. Samsung should also work in battery charging department in his future phones.
2 Comments
ysssk
No such problems on S20 FE 5g. Perhaps you've a faulty unit. Do take your phone to service centre
VC001
Beginner Level 4
Same issue here also with my s21fe. Using in power saving mode. Still idle drain is very high(6-7% overnight).
Earlier I was using android one phone. It was beautifully optimised by Google. It's idle battery drain was less than 1% overnight.
Samsung Software Developers should do something about it.
