S21 Ultra Bluetooth connection issue
(Topic created on: 12-15-2022 11:18 AM)
manoharanunni
Bluetooth connection lost and connect several times per day
BT headset Oraimo freepods pro
6 Comments
Rajkabeer
Bluetooth not open
Rajkabeer
My bluetooth not open
rsut
Connect issue
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please perform the below mentioned steps to resolve the issue:
* Forget the Network: Go to apps screen >Settings >Connections > Wi-Fi >Wi-Fi network >Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
* To improve recognition performance, register fingerprints of the hand used most often to perform tasks on the device.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
manoharanunni
Dear All
Problem solved
Please off Music share button on Bluetooth advanced Settings..
Sid_Karna
Bro is there any static noise on your oraimo tws? That's a small hissing sound for 1 or 2 seconds after the music is paused.
