S20 Fe 5g battery replacement cost?
(Topic created on: 11-23-2023 01:58 AM)
Saajan_yk
Can we replace battery of S20 FE 5g? If yes what will be approx price for that?
9 Comments
TechyKamal
ThePhotography
Around 2k INR
Me too facing same issues in my S20 FE 5G.
Just having some queries regarding Battery Replacement,
Do we get battery of same capacity or less?
And how is the battery backup after replacing the Battery?
TIA
maguisam
I have a s20fe. Problem shows after a software update. I got free replaced in Warranty but same problem faced after 4 days.
adsun
For the past 2weeks, I have also facing the same issue with my S20 Fe, The phone is draining too fast and once is getting OFF not recharging immediately. I have diagnosed the battery, it shows the battery is too weak. I'm using only a Samsung charger of 25w from starting. what may be the reason? and at the same time, my brother s21+ also showing the same issue.
keshav001
May be
Am using 15 watt charger nd charge till 85
It's showing me battery health normal. I am planning to get it replaced
adsun
around 3.5 k inr
yogeshborad
I am also facing the same issue
Bigge
Battery health was fine till Jun after that my battery is getting weak and i could really feel that before i could go for day without charging now I have to charge two times or three times a day
