S10 plus battery issue after latest security patch
(Topic created on: 10-21-2020 04:30 PM)
RohannSerpes
Anybody facing battery drain after latest security patch on s10 plus
5 Comments
Not applicable
no ... because we use smart switch to install software which is process..not by mobile data or wifi especially when Samsung provides non A/B partition type ota software not like vivo or oppo
girish4
Iam too facing battery issue
cs-member13
Expert Level 4
Dear Samsung Member,
We apologize for the inconvenience caused to you. To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
RohannSerpes
I have switched NFC off, and have observed that d battery now is not draining quickly
same issue here
