S10 is causing frame drop, heating, lag and ping fluctuations issues.
(Topic created on: 08-10-2020 03:57 PM)
VaibhavThamman
After the new August update PUBG is not running smooth like which it use to work in June. After the July update s10 started causing problem and even in August update. Game is not working properly. Throttling issues started again. It's the exynos chip which is not capable of running high end games. Phone doesn"t work properly. Game drop frames too much. Exynos is not well optimised. It is only capable of running high end perfomance things only upto one year. If you want good perfomance you should go for Snapdragon varient from US.
cs-member13
Expert Level 4
Dear Samsung Member,
We apologize for the inconvenience caused to you. We would request you to kindly raise your concern under the Ask Question section from Samsung Member Application with more details, so that we can help you out with this.
Samsung member application > Click on get help > Send feedback > Ask question.
