10-18-2020 12:46 AM in
Galaxy S- Mark as New
10-18-2020 12:51 AM in
Galaxy S2nd due to huge notification enable.
for e.g ; Google has huge notification which we don't need at all see image just scroll down image and check how many notification it does have.
So do these settings to stop, which consume unnecessarily.
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Galaxy S3. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
7. Google >click on 3dot>usage and diagnostics >off this option.
10-18-2020 01:05 AM in
10-18-2020 05:32 PM in
10-21-2020 10:25 AM (Last edited 10-21-2020 10:27 AM ) in
10-18-2020 03:11 AM in
Galaxy SI have added all unused apps to sleep and all apps background activity is off except very few apps like whatsapp , Gmail and Microsoft teams.
that's it you will see major difference
please use dark mode always to save more battery
and do not use mobile while charging.
10-18-2020 07:11 AM in
Galaxy Snot in LCD displays
10-18-2020 10:18 AM in
10-18-2020 06:27 AM in
Galaxy SIt should provide a great battery backup
I am sure this could be because of the new OneUi upate.
As many of them are facing issue after this update
Btw i am using S20 FE which is equipped with exynos and battery is draining at a rapid rate
