Ringtone selection problem
(Topic created on: 09-10-2017 10:07 AM)
Ayanjeet
I have downloaded .aac file from whatsapp msgs and I would like to set that music as my ringtone. Could anybody guide me.
6 Comments
Addyzaccount
is it visible in google play music app?
Ayanjeet
yes it is visible.
admin_
"Thanks for sharing your concern. Kindly check mentioned steps to overcome the issue.
1. Go to setting >> Profile>> add ringtone>> select file .
In case the issue still remains, we welcome you to approach us via remote access feature under support option in Samsung Members App.
Ayanjeet
thanx admin.. Issue is resolved. but due to some unknown reason I could not able to add the particular ringtone, then from my files I copied the tone in ringtone folder, and the problem got resolved.
AnujJerry
hi Admin..i am using samsung j7 prime, and i have downloaded ringtones from google.But i am not able to use them as my ringtome.I have followed the steps already_ settings- ringtones- add from phone- it shows as adding as well but it doesnt get added.Please help
Sivanagakumar
hello admin.. At present I am using a custom ringtone and now I want to set any system default ringtone.. when I open the settings to change the ringtone.. I am asked to select the path... where should I search?? Please help.. thanks in advance..
