Resolved! Solved
Request for assistance with charging problem.
(Topic created on: 10-21-2024 08:10 AM)
Rupeshchowdary
My Samsung Galaxy S24 device is not charging at the expected rate despite using the original Samsung adapter. Initially, there was an issue with the Type-C charging port due to the presence of moisture, but I have since ensured that there is no water content present.
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and go to service center for check and resolves this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
3 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung Member,
As per your query, we would request you kindly visit the service center and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
