Remote Unlock not enabling
(Topic created on: 01-13-2020 08:50 PM)
sapan97
in my Samsung S10...remote unlock in not turning on...even after entering my pin it doesnt turn on....help me
5 Comments
Bro, its working in my S10+
try normal phone reset settings once
settings>general management>select reset>click on reset settings
or
check if all settings are properly enabled or not
or
sign out of your account and sign in once again..
or
change your pin/pattern/biometrics and try again
just give a try..
Not applicable
steps👉 go to app then select system app by clicking top right 3 dots....search for find my mobile.......clear catche of it......again 3 dot right top of find my mobile......uninstall update.......go back to biometric and security.....find my Mobile.....try now👍👍
sapan97
thanks bro it helped
Samsung_Support3
Hi there,
Please follow the below mentioned step to resolve the issue:
> Perform the reset settings (settings>>general management>>reset>>reset settings).
> Please once again enable the find my mobile option (settings>> biometrics and security>> find my mobile>>enable the same>>then enable the remote unlock>>enter your Samsung account password>>then enter the backup pin>>it will automatically enabled).
>If still issue not resolved, kindly send us the error log files using Samsung member application by following below mentioned path-
Open Samsung member app>click on “+“icon>send feedback>Error reports>attach log file.
Note: For better assistance, please send device log files within 15 minutes of issue occurrence along with the exact issue details.
Regards,
Team Samsung Members
Samsung S20 ultra
