Regarding charging issue
(Topic created on: 07-24-2025 02:19 AM)
rishu1508
Hello guys iam facing the super fast charging issue as it only chargers my phone roughly 5 to 6 min then switch back tho normal charging i have done all kind of settings everything but hence it was not solved yet can anyone tell me whats the issue behind this (is it a software update which is messing around) .
I have samsung s24 fe currently running on ONE UI 7.
10 Comments
NiajN
It's your adapter, please replace it. Make sure to use only the original Samsung cable that came with the box.
rishu1508
Its all orignal even the brick n cable
NiajN
Just try with another cable.
rishu1508
Done this also i have to samsung chargers not working any but used the iphone cable n brick and the phone is charging at only fast charging not super charging
goodthings
It's a major update reset factory data with backup then try to it's again also use only Samsung's adapter and cable alsocharge your's device in cool atmosphere . If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
rishu1508
Ig i will choose to go to service center then will think of any reset n all
goodthings
As you like. Thanks.
goodthings
You're welcome to here.
rishu1508
Thabks to all for your helpfull idea 🙏
