Regarding Blootooth device volume
(Topic created on: 04-28-2025 08:53 AM)
Vaibhavpadave
From last 4-5 days I am observing that I am unable to increase volume of blutooth devices. These same devices are working fine on other mobiles. What could be the issue ?
11 Comments
Not applicable
All bluetooth devices or just earbuds?
Vaibhavpadave
All blootooth devices
Not applicable
Vaibhavpadave
Yes
Not applicable
It's a media volume limit, it's to protect your ears,
To turn this off:
1. Go to settings
2. Search Media Volume Limit
3. Turn the toggle off
Vaibhavpadave
This function is already off
Not applicable
Maybe you have set the limit on your app then inside youtube or Spotify settings, try with different application, like play any audio on chrome and try there if you can increase volume or not
Vaibhavpadave
I am using boat ear band and realme buds
UrNa
Hey! I had the same issue on one of my S24Us and a simple disconnection of all bluetooth devices, and a restart did the trick.
Here's what I did:
1. Turned off separate app sound.
2. Disconnected all BT devices.
3. Turned off BT
4. Restarted.
