Reduced Call Audio Volume on S9+ Exynos
(Topic created on: 04-24-2020 08:45 AM)
Eames
I ve been experiencing reduced audio volume when in calls. Mostly after the March Update.. any one facing the issue or its just me.
2 Comments
Not applicable
yes
cs_member9
Dear Samsung Member,
Kindly follow the below mentioned step to improve the performance of the device:
Check device in safe mode: Using Safe Mode on a Samsung phone or tablet allows you to force the device to run the essential operating system, and disable most 3rd party applications.
Enter safe mode: Press and hold the Power key, when Power off icon appears.>Press and hold the power off icon.
Exist safe mode: Press volume down and power key simultaneously for 5 seconds to restart the device.
Note: If your device functions correctly in Safe Mode, it is most likely that the issue lies with a 3rd party application that can be uninstalled to resolve the problem.
For further assistance, register your concern in Samsung Members Application (Samsung Members App > Feedback >Error report > Attach log file for any issue)
