Problem with the Battery on S10e
(Topic created on: 01-20-2021 01:39 PM)
abijitms
Beginner Level 4
After the latest Android update to 11, my S10e has started giving battery issues, like: Slow charging even after using the OE Samsung fast charger & also it took almost 5 hours for full charge & after unplugging the charger the battery drains out very quickly.
Can anyone suggest any methods to see if something is wrong or do I need to check anything??
Thanks in Advance 👍🏽
5 Comments
ChandanMallick
This happens with the new update but it will get fixed with future updates. Now you can just give your feedback to Samsung authorities
Ehsank
If after update then wait for few days, and as of now perform these below steps;
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable/type C earphone only for Android 11)
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
Ehsank
and if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
kb95
Beginner Level 3
same issue. My phone won't even recognize the charger and earphones sometimes. Have you found any solution?
I am unable to wipe cache partition as well because that screen won't even show up.
let me know if anything worked for you.
Samsung_Support1
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
