Problem in quick panel after one UI 8
(Topic created on: a week ago)
roarx
When I updated my phone(s24 ultra) to one UI 8, the quick panel became transparent, is it a feature or only in my phone?
roarx
But i had enabled it, even when I had one ui 7
YesImAk
The problem that you mentioned is happening because of that feature. It changed with OneUI 8.0 and the only way to fix it is by disabling the feature
roarx
Are you sure?
YesImAk
Yes. That setting doesnt make any major difference in performance anyway so having it enabled is useless
roarx
roarx
YesImAk
Next time dont change settings you dont know about.
roarx
I can't read ur previous comment, plz write it again here
YesImAk
I said that settings disables all the blur and transparency effects from your phone; that's why you can see the wallpaper clearly when you have it disabled. And it only affects appearance, so it's a personal choice if you want to use it or not.
roarx
It was my personal choice, that's why I enabled it, if they have changed that feature of this setting in one UI 8, i want them to change it back
