Resolved! Solved
Power bank for Samsung S23
(Topic created on: 06-29-2024 10:11 AM)
atulx07
I need a Power bank for my Samsung S23. Which one I should buy so that it doesn't affect battery?
Sáyân15
You can use any power bank of reputed brands that supports USB PD & PPS protocols which will safely fast charge your S23 without damaging its battery.
I have my old realme 20000mAh power bank which supports upto 18W of max fast charging & supports all the fast charging protocols that i mentioned above. It’s charges my S23 pretty well...
2 Comments
RushiLee
I am using Ambrane 10000mah 20W output one power bank which cost 1000₹. Even it has 20W output it is fast charging my S23 phone.
Sáyân15
