PUBG config for 90fps HELP!
(Topic created on: 03-25-2021 04:59 AM)
OwerlordX
Hello.
I saw there is a method to play PUBG in 90fps or ultra hd option on any phone so I tried to do it. But when I go into Android/data/com.tencent.ig/files/UE4Game, there should be a folder called ShadowTracerExtra which I don't have. Any advice?
I have got an S21 Ultra (exynos)
4 Comments
I also need
Not applicable
Try to access android folder from a thirdparty file manager because you cannot view or modify android folder using your built in file manager as per android 11 policy.
Files by Google won't work
Something like solid file explorer or zarchiver will work
sanityop
Beginner Level 4
Those file manager don't help ..found any way to force 90fps?
karan001
Hlo bhai
Aapke phn s21 ultra me
Smooth +90fbps supported ba kya ya ni after update
