One UI 7 battery widget battery percentage not visible.
(Topic created on: 04-27-2025 12:57 AM)
Vishy05
I have recently updated to One UI 7 on my S24 Ultra India version.
I am unable to see battery percentage in my battery widget. All other widgets are working fine.
10 Comments
Atharva95
How did you get dark icons ? Which apk file did you install ?
JordanxSandhu
One pro dark APK is free and malware-free! I tested it on VirusTotal. Download it from 9mod.com
BeAstBaymaXX
Since this update is in beta phase, there are tons of bugs that you might encounter, as the one above. Don't worry, Samsung will eventually release an update and fix this. They are aware of this bugs.
If you like my comment, do mark it as resolved😊
Vishy05
This is a stable release friend. S24 Ultra has been receiving stable one ui7 build from last week.
BeAstBaymaXX
Ya I know that S24 has received the stable one but in this version it has occurred a lot of bugs. Many users are daily reported it. Samsung will in the coming days release an update for this hopefully.
Vishy05
Okay. Thanks.
Janmajaya123
Samsung users, we need your voice!
You also suffering from any issues that you have? You're not alone!
Like, comment & support this post to make Samsung listen!
Click now: https://r2.community.samsung.com/t5/Galaxy-A/Samsung-s-Response-Isn-t-Enough-Look-What-They-Said/td-...
Vikrantniku
Beginner Level 5
Even when I activated battery percentage it's doesn't show anything in status bar ... I have activated it but doesn't show battery percentage at all 1745720672105.jpg
Vishy05
You can check if battery icon is enabled in quickstar module of good lock.
