Notification sound not working ringer not working
(Topic created on: 07-09-2022 12:38 AM)
Aceswolf
So I have been up down left right and tried all the "SOLUTIONS"  I could find on here.
NONE have worked.
I have sound... Watch videos and such no problem. If I'm watching something the notification sounds / ringer makes the sound.
However if the phone was just sitting with the screen off ( Not the phone off just the screen not on to save battery) It does not make a sound.
Please help and don't tell me go to notification make sure its on cause like I said I have tried 15 different "SOLUTIONS" NONE of them have worked.
Thank you
2 Comments
Onthatile
Beginner Level 4
Hi, I'm not sure if this would be any of help or not,but try going into settings>general management >Reset>reset all settings
Tsogo_sam05
Hi Acewolf,
Thank you for reaching out to us and we apologize for the inconvenience,
Please try phone reset
1. Settings
2. General management
3. Reset all settings
Once that is done please perform a soft reset of your device.
Press and hold the power and volume down buttons for about 10 seconds.
*The device may take a screenshot, however, keep holding the buttons for a few more seconds.
