Night mode not work in S21 Ultra 5G
(Topic created on: 03-31-2021 12:11 AM)
massage
Night mode not work in S21 ultra 5G in april security patch. Previously in march security patch sw, night mode work very well.
7 Comments
Not work means? Completely dead?
Once reset camera to default settings
Also clear camera cache
massage
Not work means in night mode pic not getting clear, not getting iso works, getting pic black dark, not even 1 object found in this pic.
Drop feedback to Samsung via Samsung members app..
Ehsank
you can send feedback to Samsung by using get help section
GetHelp>>SendFeedback>>ErrorReport/AskQuestion>choose appropriate section
And if possible do visit service centre
Samsung_Support1
Dear Samsung Member,
Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
saluuu786
Beginner Level 3
Ziffyjacobs
Power off your device, make sure it's off then press and hold the volume up button and the power button till the phone boots up, you'll see some options, using the volume rocker, navigate downwards to "repair app" that did it for me. I wiped the partition first before I used the repair app option. Not sure if it's a combination of both or repair app option only that did it.
