Network problem
(Topic created on: 01-23-2026 05:05 PM)
vccc132
Mere samsung s 24 me kuch apps open nai ho rahi hai .aur na hi google par agr Flipkart app open krta hu tu network issue bta Raha hai .yha tak ki members app open nai ho rahi wifi se open Krna pad raha hai koi bta skta hai kya problem hai
8 Comments
Which network you are using
vccc132
Airtel
goodthings
Please reset all settings in general management settings also flight ✈️ mode on and off one time also optimize your's device in device care too also clear cache of all Apps manually also update your's all Apps too then try to it's again. If you like please accept it's a as solution it's help to other users also,click on 3dots in my reply section and click on accept solution. Thanks.
vccc132
Nai hua in sab se
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update it's maybe fix by Samsung team soon. If you like please accept it's a as solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member8
Dear Samsung Member,
● Kindly check the device in different locations/network coverage areas.
● Check Mobile Network: Settings> Connections>Mobile networks> Network mode> Select 5G/LTE/3G/2G (auto connect).
● Check Network Operator: Settings> Connections> Mobile networks> Network operators> Select automatically.
● Kindly check the same SIM card in another phone or another SIM card in the same phone to verify the issue.
● Kindly try to contact the service provider once.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
● You can reset your device by following the steps from the below link.
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Khetesh
same problem mere sath bhi h
