Network problem
(Topic created on: 09-13-2025 02:29 PM)
deepak2525
My s22+ have some network issue last few days
5 Comments
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also restart your's device without any Sim in slots also interchange Sim in slots also turn off power saving mode also optimize your's device in device care too also clear catche of all apps manually also update your's all apps too then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
deepak2525
Already done so many time
goodthings
goodthings
You're welcome to here.
cs_member8
Dear Samsung Member,
● Kindly check the device in different locations/network coverage areas.
● Check Mobile Network: Settings> Connections>Mobile networks> Network mode> Select 5G/LTE/3G/2G (auto connect).
● Check Network Operator: Settings> Connections> Mobile networks> Network operators> Select automatically.
● Kindly check the same SIM card in another phone or another SIM card in the same phone to verify the issue.
● Kindly try to contact the service provider once.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
● You can reset your device by following the steps from the below link.
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
