Network problem
(Topic created on: 07-07-2025 01:56 PM)
Shreyuuu
Samsung s21 fe network problem 5G network not stable this is bad things for user.
11 Comments
vjvinamara
I understand your concern about the 5G stability on your S21 FE. Often, this kind of behavior (unstable 5G, switching to 4G/4G+) is due to the network's signal strength in your location rather than the phone itself. You might want to check with your network provider about 5G coverage in your area. The phone should automatically switch to a more stable 4G/4G+ connection if 5G isn't available.
Sam6222
Same problem in A35
I am in city Bangalore ?
vjvinamara
Could you please tell me which mobile carrier you are using? I am with Airtel, and I have observed that it frequently switches between 4G and 5G in many locations I have visited.
Sam6222
Yeah mine Airtel
vjvinamara
I understand; it seems there might be a problem with Airtel, as it appears to switch between 4G and 5G connectivity irrespective of the location. 📶🤔📱
Sathish08
No brother there's a bug. Other brands phones are getting stable 5g. While s21fe struggles with 4g
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
Shreyuuu
Over hitting is not problem but big problem is network 5G speed is good but switching in 4G network speed is poor ☹️
