Need a piece of advice
(Topic created on: 03-20-2022 09:39 AM)
Anuj_382
Greetings members!!
This morning i have contacted samsung support vis the members app, have told them the problem about the "quick panel" and how it is annoying. They told me to visit a service centre for the inspection of my device.
Now, my device (s20 Fe 5g) is barely 5 months old, should I visit the centre??
5 Comments
Not applicable
So what is your issue with quick panel??
Anuj_382
Stutters while pulling down the notification panel for the first time, after that it becomes smooth
Sid_Karna
You mean laggy quick panel? You need not go to service center for that. It's a software bug.
Anuj_382
Yes. I am also thinking of not going.
BTW do you use power shade app?
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
