Need Help
(Topic created on: 05-26-2023 05:40 PM)
sanjoybagchi
Dear All,
I am using samsung android mobile. Recently i have changed my one sim, but when I am trying to register hotstar or other app , when I am trying to put number the android showing continue with my old number, how I replace that my new number.
Thanks
7 Comments
Alex_Paul
If you have your old sim, then you have to put it again, otherwise you have to create a new account, on your new number. 😔
sanjoybagchi
How can I do that pls help
Alex_Paul
You have to put your old sim brother! I hope it helps...❤
sanjoybagchi
Ok
GalaxyDip
Reset your phone
sanjoybagchi
Ok
Alex_Paul
Reset is not a solution, you have to put the old sim, otherwise create a new account on hotstar.
