Multi touch problem
(Topic created on: 07-27-2020 07:17 PM)
warrior13
I have an s8 plus for 2 years. Recently my multi touch isnt working and it detects only 2 fingers at a time only and that too not perfectly. I realized that while gaming which requires more than 2 fingers to use. I used a third party app and checked how many fingers were registering at a time and only 2 were.
Please help because I wont be able to afford another mobile and theres no solution anywhere. Thanks
You can search for each in settings search bar.
warrior13
all of them are switched off
I have found two solutions, one should work:
1- Reduce your screen resolution in Settings > Display > Screen resolution.
2- Go to your phone dialer and type *#2663# then update TSP, check the attached screenshots.
Let me know if any of solution works.
Jeson lama
I dialed that code, nothing happens
warrior13
I've done both. made no effect
Did you tried on HD+ resolution? try to increase and decrease the resolution.
warrior13
I tried that. still the same
This issue can be caused by a bug in the game that you are playing.
I've just downloaded a game called Magic Piano from play store to try 3 finger touch 😅
You can download the same game to try out your multi touch.
Let me know.
warrior13
I tried it. only 2 are registering 😭😭
warrior13
I'll try that now. but the thing is I used a third party app called multi touch to test it. and max of 2 fingers is getting registered
