Multi touch problem
(Topic created on: 07-27-2020 07:17 PM)
warrior13
I have an s8 plus for 2 years. Recently my multi touch isnt working and it detects only 2 fingers at a time only and that too not perfectly. I realized that while gaming which requires more than 2 fingers to use. I used a third party app and checked how many fingers were registering at a time and only 2 were.
Please help because I wont be able to afford another mobile and theres no solution anywhere. Thanks
49 Comments
Hi, please check the link below for helpful tips, let me know if any of the solutions was helpful :
https://thedroidguy.com/galaxy-s8-touchscreen-not-recognizing-finger-touches-troubleshooting-guide-1...
warrior13
I tried the methods except factory reset. nothing worked
it2
hey, did you got the problem  fixed? in currently  facing this issue
warrior13
should I give it to a shop? its risky going outside now
Go to settings > display > switch on Touch sensitivity, let me know the result.
warrior13
the touch sensitivity option isnt there in display.
Go to settings > accessibly, then check if the following options are switched off ( Touch iteration, accidental touch protection, ignore repeated touches)
warrior13
can you give me details on this?
