Moisture Problem
(Topic created on: 10-11-2019 06:27 PM)
vaibhavbhat08
Guys I'm getting moisture problem on my Samsung Galaxy S9.I can't charge my mobile using usb charger.How can I solve it? Please help me
13 Comments
ani1985
first of all you have to take air dryer and gently put in front of charging female port and let dry moisture then you can charge the phone
UDStrs
you have three ways to overcome this
most safe method is to override the algorithm
power off the device . hold power and volume down bottom and immediately insert the charger im mobile .. wait for the charging sign come up on your display and yout phone will vibrate once and display will be off .
than release the volume key and let the phone power on
override done if even after waiting for 2 hrs the same issue rises apply this
vaibhavbhat08
I tried.But still I'm getting
satish90
going service centar
lalittt123
nothing to do just charge it via wireless charger only for 10 min after tht u can easily charge it via usb cable
ishashankg
moisture problem is not only occurs when ur phone got moisture in charging port. Try changing chager with cable. even after this occurs need to replace ur charging port as it has short circuit.
GunnerBomb
same issue earlier, issue resolved successfully
vaibhavbhat08
How?
GunnerBomb
get some liquid dettol inside port and pour tap water facing the port towards tap water.
After that take cotton and insert inside the port and clear cache android system.
