Resolved! Solved
Moisture Detection issue on S21 FE
(Topic created on: 08-01-2025 08:37 AM)
Shivam762
I am receiving a warning on my phone (S21 FE 5G) since yesterday about
" Moisture or foreign materials detected in USB port"
1. I have tried cleaning with hair dryer, tried to shake it gently and kept phone switched off over night.
2. Tried cleaning USB cache
3. Tried resetting setting.
But issue has not been solved.
Phone charging works with same cable for a while and then it disconnect saying moisture has been detected.
Sometimes it works on power off mode, sometime it doesn't.
I have attached a screenshot of the warning.
Warning of Mositure/ Foreign materials
Can somebody help me with this issue ?
Resolved!
12 Comments
Shivam762
Tried it in safe mode. It worked. Afterwards, switched it on in normal mode, it's charging with same adapter and cable it was showing error.
Thanks for helping me🙏.
YOUR_EX
Don't worry bro,its nothing problem 😊
RonnyGupta
I also faced same issue i tried wireless charging for 5 to 10 minutes then use cable charging it will work perfectly .
