Missing smart Select screenshot in edge panal
(Topic created on: 3 weeks ago)
kishor_23
After one ui 7 android 15 update in samsung s21 fe smart select screenshot is not showing .
Is it is renamed or removed?
5 Comments
MukeshSahoo
It's actually revamped into new AI base selection
If you go to edge panel, there is a blue colour scan option in app section.
It's has almost all functionality of smart select screenshot.
kishor_23
😅can you provide some screenshot. I was unable to find it
MukeshSahoo
I think it will be enough to guide you.
kishor_23
Thanks a lot man ❣️
cs_member8
Dear Samsung Member,
We would like to inform you that Samsung provides software updates to remove bugs and bring new features and enhanced security to your device. These updates are specifically developed to improve the performance and stability of your smartphone.
Your feedback is incredibly important to us as we continuously strive to enhance our products and make them more efficient. We appreciate your valuable input and are committed to delivering the best possible experience.
