Lock Sound
(Topic created on: 06-04-2024 10:47 PM)
SAGAR2514
Can i change lock sound on Samsung Galaxy S23 Ultra ? If yes How. ??
8 Comments
unknown_s
Yes, you can change the lock sound on a Samsung Galaxy phone or tablet:
Swipe down from the top of the screen to open the Quick settings panel
Tap the Settings icon
Tap Sounds and vibration
Tap System sound
Choose a sound theme to use for touch interactions, charging, changing the sound mode, Samsung Keyboard, and more
unknown_s
you can Also change your lock / unlock sounds by editing Android's Global Table
SAGAR2514
Tried but not able to change lock-unlock sound.
unknown_s
Did You Have Tried The Second Way Using Android's Global Table??
SAGAR2514
Nohhh
unknown_s
Then It's Not Possible!!
I Have Also Searched Many Way But Not Possible
Bad Luck😕
SAGAR2514
Ok thanks.
Umangmathur
It's not possible I think
