Lens flare on s20 fe 5g, anyone else have the same problem?
(Topic created on: 02-17-2022 08:47 AM)
Akshays20
14 Comments
Not applicable
Are you using any lens protector ?
If yes then remove it then see
However when the camera is exposed to direct lighting then lens flare occurs
Akshays20
No lens protector, it only happens in artificial lighting direct sunlight doesn't cause flares
Not applicable
It also happens in direct sunlight 🤔
Akshays20
Just checked , the problem persists
Not applicable
It happens in direct lighting ....
Can you share a picture of camera system ?
Akshays20
Picture of the lenses?
Not applicable
Yes
Akshays20
.IMG-20220217-WA0005_78216_1645074441.jpgIMG-20220217-WA0003_78213_1645074440.jpgIMG-20220217-WA0004_78219_1645074440.jpg
Avoid direct contact with light..and clean lens properly
