01-28-2024 09:20 AM in
Galaxy S- Mark as New
01-31-2024 10:03 AM in
Galaxy SThe LED indicator is located at the top left of the front of your Galaxy phone. It displays various colors depending on the notifications and functions of your phone. Please note that not all devices have LED notifications. Instead, you can use Flash notifications. Open Settings, then tap Accessibility, and then tap Advanced settings. Tap Flash notification, and then select your desired options.
However, the following list can be used as a reference guide if you are seeing LED notifications.
Blue (pulsing): the device is turning on or off.
Blue (blinking): there is an unread notification (missed call, message, etc.) or during voice recording.
Red (glowing): connected to a charger and charging.
Red (blinking): connected to a charger but not charging, or when the battery is low.
Green (glowing): connected to a charger and fully charged.
Green (blinking): fully charged.
Other colors: If you have installed third-party apps that include LED notifications, your phone may blink different colors (such as white, purple, or pink).
