LED Indicator on Galaxy S10+
(Topic created on: 03-22-2019 08:53 PM)
SuperMario89
Hi dear members. Could anyone advise me if the S10+ has the LED feature like the S9 range. I was able to set colours for thr indicator on my S9+ previously. This helps alot when you see the blink to know you have received emails or messages.
Thank you in advance
3 Comments
Maxell
sorry mate.there is no led feature in the S10+. hopefully samsung can use some pixel in the display.😊😊
vinodm
no indicator...but there is awesome moving light around front camera
iRozen
I don't know exactly what led notification you're talking about but you can go to Accessibilty > Advanced Settings > Flash Notification... Those are the choices.
If you want the Edge Lighting notification. You should use a third party app for the meantime. You can download and install AOE (Always On Edge) App.
Hope I was able to help you.
