Led notification indicator no longer working
(Topic created on: 02-14-2020 11:23 PM)
ècious
Why led notification indicator no longer working on my Samsung s9 after updating to android 10?
5 Comments
just try going to settings and check the notification panel
Try whether you turned it off accidently.
Settings>Notifications>LED Indicator.
If its on and the led is still not working, Dial *#0*#, it will open a test memnu. From the menu there is an option to check LED. Do a check up and let us know the result.
ècious
I have already checked that and its working perfect when I dialled *#0*#. I checked on my settings its on,but I doesn't work when I receive any message or a missed call. This started when I updated to Android 10
Try clearing data of Settingss app.
Samsung_specialist
Hello,
You can confirm that the option is enabled from Settings>Notifications>LED Indicator, If the issue still, please check it from *#0*# and select LED, if the issue still,  we advise you to visit the nearest  service center.
www.samsung.com/sa/support/servicelocation/.
Thank you
