Issues with fast charging after Android 12 upgrade
(Topic created on: 01-06-2022 02:05 AM)
Kru-zz
The latest Android 12 update broke my fast and super fast charging on my S20 + with original Samsung cables and new Samsung cables! Shame. Enough to make you want to shift OEM.
8 Comments
Kru-zz
Dont upgrade, no fast charging makes the phone useless, and it seems its a common issue happening for a while now.
BasilJJ
I have s20 plus and the super fast charging works fine with android 12. I noticed before I updated the phone that sometimes it does not work if the battery level is below 10.
Screenshot_20220106-045735_Android System.jpgScreenshot_20220106-045538_Gallery.jpg
Hi there, have you tried with another cable?
Kru-zz
Battery level above 10, and tried different cables, outlets, powerbank.. nothing works. I can see also that users with an S21 receiving the android 12 earlier complaining about the same...
MoeG6
Did you try to factory reset your phone? Or try to boot into recovery mode, wipe the cache, and/or reset the phone from there
Kru-zz
I tried all but will not go in factory reset, again this is a Samsung upgrade that should be tested, but it seems not enough, as the issue appears S21 upgrading earlier
Ferra85
I have same issue with my S20
tml713
I have the same issue.
S20+ 5G.  Android 12 broke fast and super fast charging, and also will now not charge at all from most of my other chargers (in car, usb-c laptop adapters).  Of my many USB chargers that i used before, only 1 will work now.  Samsung please fix!
